johnny whaler
Thread starter- Joined
- Sep 4, 2006
- 56
I have a 78 Evinrude 35hp on a 1963 13' whaler. I took it out last week after I bought it and had it running and it ran great after I played with it in the driveway for a while. Once out on the water it ran great but tended to cough and spit on idle and it wasn't real smooth. It hadn't been run in a long time. It wasn't pumping real great and the local boat yard mechanic said they are famous for a stuck thermostat. He pulled it out and repalced the head gasket too at the same time. Once again it ran great in the driveway but I got it out and it ran ok but then started up again coughing and sputtering and then fouled the plugs. I put in a new set and it ran ok for about 15 minutes and fouled them too. Did the same with a 3rd set.
The only setting I see it the low sped setting and I was told to start at 3 turns. It runs turned down to one turn and all the way up at 3 turns. It really is strange. It runs like new with new plugs then go to heck in 10-15 minutes.
I ran QL77JC4 plugs and L78V plugs and it did the same with both. I am thinking it's a carb problem. I did notice that the last time when I opened the engine cover there was some fuel that came out of the front of the carb along the airbox.
Any suggestions as to where to start is appreciated. I bought it knowing there were issues. The previous owner was told by the big boat dealer in Norwalk that it had a bad crank seal but the thing has 140PSI in each cyl which I though it would never have with a defective crank seal. Not sure how to tell if this is the problem or if they just didn't want to work on a 1978 outboard. Any idea what the symtoms of a bad crank seal are?
It's too good to throw away...help if you can...Thanks!
