Re: 60 hp throttle up problem
Assuming it's a 1990/1991 engine,there are idle or slow speed mix adjustment screws on the starboard side of each carburetor.Lightly seat "clockwise" all three of them one at a time and back them off counter clockwise 3 1/4 turn.Reason for seating them clockwise first is to know where each are currently set at for reference.
Next ,with the throttle lever in the neutral position,note whether the throttle cam roller is "exactly"aligned on center with the scribe line of the fiber throttle cam.and "just touching." All three carb flaps at this setting should be fully closed.There is a lock screw that can be loosened and retightened to perform this critical adjustment.
Once these settings have been attained,with engine not running,shift into forward gear while spinning the prop and advance throttle to its wide open position.Note that each carburetor flap opens to their fully horizontal position.If one or more don't ,there are lock screws on each carburetor linkage plate that can be loosened and retightened to perform this procedure.Once completed always then operate the throttle lever back to neutral to insure each are still closing fully.Fine adjustment may be necessary.
Then ,give her a rip in the water and see if your flat spot is gone.You may even find that 3 1/2 or slightly more turns of each idle mix screw is necessary to richen up the low end mix to eleiminate the throttle up flat spot.Keep a screw driver aboard with you for fine tuning .
