fuel restriction
Jason Edwards
I have a Johnson 200 Oceanrunner pushing a 23' Promaster. Where would you begin looking for a fuel restriction? I don't see any lines kinked. Could it be the anti-siphon valve? If so, how do I check it?
rwise
Re: fuel restriction
my first thought would be the fuel filter
Joe Reeves
A fuel restriction should have the warning horn emit a steady constant beep, same as overheating.
(Fuel Anti Siphon Valve)
(J. Reeves)
Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vaccum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve.
Jason Edwards
The reason I think its a fuel restriction is when I am running the boat wide open and trimmed out the check engine alarm emits a solid tone. The alarm only sounds when the engine is running wide open. I would haved assumed that the engine was overheating only I can only get 5000 rpm out of the motor when it should be turning 5800. I'm running a 14 1/2 x 20 prop so I don't think I am overpropped. Am I looking for the right culprit?
