Need prop starting point.
roscoe
Hi guys.
History:
I bought this little 16' Alumacraft a month ago. 2 bench seats, and a single seat console helm. Book says it weighs in at 380#. Rated for 65 hp !! !!
Total weight boat motor batts fuel gear, and me = 1000#.
It was powered by a 1977 Evinrude 35 hp. I replaced the damaged prop with a "stock" 10x13p and brought the rpm up from 4300 to 4700. Then I raised the motor 3 inches and got the rpm up to 5100 at 28+ mph.
Problem:
I really needed power tilt for my back and shoulder.
Solution:
I bought a 2001 Mercury 50 hp 3 cylinder 2 stroke with power tilt and trim.
And the engine is rev limited to 5700 rpm.
Question:
Where do I start to prop this new motor?
Boat, new motor, batts, gear, bigger fuel load and me = 1100#.
I went to the Merc site and punched the info into their propfinder program.
It recommended a 13p prop. Doesn't seem right.
If the old 35hp and a 10 x 13p prop is right.
Then shouldn't the 50 hp need a 10 x 17p or maybe even a 10 x 19p?
I realize I may need to buy a second prop, but I want to be close with the first purchase.
Your thoughts on a starting point?
Re: Need prop starting point.
The Merc has a 1.83:1 ratio lower unit so you might try a 15. I agree that a 13 is a little short on pitch. My fishing buddy has that exact engine on a 17 foot Lund Explorer and it runs a 13P. On your much lighter boat I would think a 15 would be in order and you might even try a 17. A 19 is a way too tall in my view however if the engine can twist it, you would have a little hot rod.. I run a 19 on my 75 HP which has a 2.3:1 ratio. If it were mine, I'd start with a 15.
Crownie2
I don't know what you entered into the calculator but I entered 16' aluminum console and came up with a 15" recommendation.
In fact it showed 15.5", 5,250 RPM's and 35.5 MPH as the calculated results.
Have fun and be safe!
Bob
I didn't use a calculator, I used known factors. However I just ran a calculator and with a 15P cupped prop on that light boat the calculator showed 39 mph using a 10% slip factor. I suspect, properly set up the boat could use a 17P provided it was run light. My reasoning is that with a 15P running a light load, the engine may actually hit the rev limiter.
roscoe
What calculators are you guys using?
I would be interested in comparing the results from several.
Which one did you use to calculate the speed?
THanks for the input so far.
I think I will borrow a 15" to try out, before I buy one.
Crownie2
Silvertip: I was responding to Roscoe, not you.
Roscoe - I used the Merc Calculator you refered to.
Bob
roscoe
Thanks guys.
Give us some numbers when you get it "fine tuned". Its always good information to file away should someone else have a similar situation.
walleyehed
I punched in 1500lbs total weight because it says 50HP is too much for 1000lbs, and it came up with a 15P, so I have to agree on the 15-17P range.
roscoe
thanks.
Will post back with results.
May be in a few weeks, or next April, as time is short and we have had hard freezes 65 miles to the north.
