*ATTN: MODS* Joe Reeves WOT Timing Procedure
jtexas
How bout putting this one in the FAQ forum?
quoting from Joe Reeves...
(Timing At Cranking Speed 4°)
(J. Reeves)
The full spark advance can be adjusted without have the engine running at near full throttle as follows.
To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary).
Rig a spark tester and have the gap set to 7/16". Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4° less than what the engine calls for.
I don't know the full spark advance setting your engine calls for, but to pick a figure, say your engine calls for 28°, set the timing at 24°. The reasoning for the 4° difference is that when the engine is actually running, due to the nature of the solid state ignition componets, the engine gains the extra 4°.
If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4° which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place.
No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting.
Be sure to use your own engines spark advance settings, not the one I picked out of the air here in my notes.
rickdb1boat
Re: Joe Reeves WOT Timing Procedure
Use the contact mods button on the right...
jtexas
Re: *ATTN: MODS* Joe Reeves WOT Timing Procedure
I seem to get the "you can't PM" message when I go that route...
svdk
Will this procedure work for my 1981 115 hp evinrude?
rickdb1boat
Yep. Guess they don't want to fool with PM's anymore...
KYHunter2
svdk, Just be sure to verify the timing.( usually very close).
At wot , either running down the lake or on a trailer in the water.
jtexas, It sure would save alot of time and typing.
How to build a spark tester is another good one for the FAQ'S.
KYHunter
JB
Appreciate your interest, JTex, but:
No make or model engine is identified in the procedure, and it is clearly make and model specific.
Whether it addresses a "Frequently Asked Question" is not at all clear. Seems to be a "read your manual" question to me.
D
DJ
Guest
I have to agree with JB. I don't know what that procedure covers.
I agree it is quite descriptive. If it fits a series of engines and they can be identified, I'm all for it as an FAQ.
Paul Moir
Seems like a frequently asked question to me. And I doubt you'll find those instructions in any manual.
Not hard to ID which engines it's for. It's too bad Iboats doesn't implement a cheap wiki so it's not squandering useful information like that. Cripes, you can't even search for it anymore!
I mean really, the mods are busy enough without having to worry about maintianing a couple FAQs, and we do need many more FAQs. They should be controlled by the contributors. A wiki would be the sensible way to implement it.
rickdb1boat
Yes, it would be nice to have a place to add info. Search here is useless as it stands....
jtexas
iwombat
It's a good FAQ and is not covered in the manuals. The manuals instruct you to crank the engine up to full advance at operating speed and measure the timing.
MarkV_Deep6
Works on a V8 Johnson. Just be sure to ground the plug wires when setting the timeing. (The Power Pak will thank you!)
Joe Reeves
The procedure I listed will work on all of the Capacitance Discharge Ignition models starting with 1973 up to BUT NOT INCLUDING the models that incorporate the Fast Start feature UNLESS one is capable of disconnecting the Fast Start feature.
i have requested Joe's permission to add to FAQ. thanks for reviving it.
thanks to Joe, it is a Faq.
sorry lost in space. with another server. bbBoard was the worst mistake iboats ever made.
