60 hp rude exhaust cover gasket 1 or 2
mopar1970
I have a 1983 60hp 2cyl evinrude and need a exhaust cover gasket my repair manual shows an inner and an outer gasket in the diagram but napa cannot get the inner one they tell me they can only get the outer one and thats all that is listed. so does anybody know if there is only one or two exhaust cover gaskets. Any help is apperciated
Thanks,
Chris
ob
Re: 60 hp rude exhaust cover gasket 1 or 2
It just requires 1 gasket.P/N 0325211
F_R
Just wonderin' how did they do that? Evidently there is no customary baffle plate between the exhaust and water. Is the exhaust passage cast in the block?
mopar1970
I have a water leak in the bottom cyl. does having only one gasket mean the exhaust cover has nothing to do with my water leak? if not where else can it leak? Thanks,
Chris
R.Johnson
The head gasket can also cause this problem. What type of boat is this engine mounted on?
mopar1970
16 ft glastron tri hull
I hade even comp but i guess there could still be water coming in
Whats the boat got to do with it?
Thanks,
Chris
mopar1970
So if I have only an outer exhaust cover gasket the only thing that could be allowing water in the cyl is the head gasket?? Can the head gasket be done on the boat?
Thanks for any help,
Chris
