bad elec. choke or fuel issues?
JoChek219
was out today on the boat, started fine at the launch,
how can you tell if your elec. choke is working properly.... wondered if that was causing my problems or a fuel issue?? drove a couple miles wide open , then putted around for a little and boat stalled. Tried to re start and would run, go to put it in gear starts to take off and stalls. Finally get going in fwd go back towards boat launch to anchor out in shallow water, we stop in neutral tieing on anchor, and go to put it back in gear and stalls out. We wait a while starts up put it in gear stalls out. Start it back up and idol around 2500rpm "try to clear it out" and throttle slowly and boat takes off runs ok, get in the outlet and boat almost stalled in outlet, eased her into the boat launch and called it a day.... obviously some kind of fuel issues... any ideas comments and advice greatly apprecitated!
Don S
Re: bad elec. choke or fuel issues?
SEE OTHER POST
Don't start another thread on the same problem, just continue with your previous post.
