1985 45hp commercial johnson
tallcanadian
i wonder if someone might know the specs to this outboard. 1985 45hp commercial outboard. model number j45rslz. all help is appreciated.
rickdb1boat
Re: 1985 45hp commercial johnson
What in particular are you looking for? Looks like a rope start, long shaft(20") 45 HP Motor. Uses QL16V Champion spark plugs, which are a surface gap plug.
tallcanadian
i appreciate that, thanks. but i'm also looking for bore and stroke, weight, all that good stuff. lol
rickdb1boat
Don't know the bore and stroke, but it weighs right at 200#...
tallcanadian
thank you rick, you know your stuff. now maybe you can tell me where to get a good power trim and tilt unit for this motor. d:)
rickdb1boat
About the only one I know of is a CMC power T & T unit..Very pricy though and have a 6" setback I believe. So steering cable length may be a problem. I'm sure there are OEM units that will fit. Just not sure which one. You might visit http://tcoutboard.com and give them a call. I would imagine a unit off a 1985(And probably other years) 50 HP would work...Once you find out what will work, visit Ebay for a better price...
http://www.iboats.com/mall/index.cgi?keywords=CMC&session_id=382824170&cart_id=808327869&list_time=1158187249&view_id=13581 ] CMC [/url]
tallcanadian
yeah, i knew about the cmc but the dealer is telling me they have no listing for my motor. age thing i guess. they also told me that there was never a power trim and tilt made for the commercial units. is a 50 hp same housing?
rickdb1boat
The CMC unit will work on your motor. Also,I'd bet the brackets are the same, so I would think a T & T unit from a 50 would work. Give those folks in the previous post a call. They will know for sure...
tallcanadian
they tell me that these units are not all that good that i should go with cmc. might be a good idea.
