volvo compression test
Status
Not open for further replies.
rubberduck
Does anyone know what a good result is from a compression test on a 1983 Volvo AQ125A?
I'm planning on testing it this weekend but don't know what range I should be in.
Thanks
Starflight
Re: volvo compression test
The book calls for 9.3:1 compression ratio and between 146-174 psi.
FWIW...it is more than 136psi.
You can't calculate the pressure just by the change in volume. You have to take into account energy introduced. This also increases the pressure.
Dunaruna
[colour=blue]
Limited-Time said:
FWIW 9.3:1 compression = 136 psi
In a perfect world - yes. But there are way to many variables to nail down an exact correlation.
Rubberduck, taking into account the age, a good result would be around 140-150 with no more than 5% variation.
Curious how you think 136 PSI in a perfect world.
Dunaruna
[colour=blue]14.7 x 9.3 = 136.71.
Maybe I should have said 'theoretical' world.
Limited-Time
Atmospheric pressure = 14.695 PSI,(at sea level) 14.7 X 9.3= 136.6 PSI
Pressure(initial) = Pressure(ATM) + pressure(gauge) = 14.7 PSI. In this case, pressure(gauge) = 0 PSI
pressure(final) = pressure(ATM) + pressure(gauge) = 136 PSI. Since pressure final = 136, pressure gauge = 136-14.7 = 121.3 PSI.
Of course the presure final will be way higher that this because the temperature is not constant. By compressing the air, a lot of energy was introduced by the work necessary to compress the air. This causes the temperature to rise drastically and hence causes the pressure to rise.
This phenomenon is what cause air conditioning to work. Ever feel the output of a compressor? Pretty hot!
I can see how you guys thought it was 136. You were assuming Ideal Gas Law but forgot about temperature rise and how pressure(gauge) works.
Don S
That's why the dreaded SERVICE MANUAL that most people seem to really hate to own, says 146-174 psi.
yeah...I bet the Clymer manual says 136.
Don S
More likely it says 631 :devil:
Dunaruna
[colour=blue]I didn't say it was 136.
If you read the posts - we all agree. But it seems we must have a maths lesson from Bruce and a shot across the bow from Don to end the thread.
it wasn't a math lesson...it was a thermodynamics/chemistry lesson!
I just wanted people to realize you cant just multiply the atmospheric pressure times the compression ratio to get the pressure.
Tail_Gunner
My money is on Don he's rarely wrong no offense guys..........
erock35
WOW!! Put on your gloves and get in the ring. This could be a draw!!:confused:
Ayuh,... Good Thing,... 'cause I ain't no Mathamagician.....
But,...
I am a Mechanic...
If I had a 9.3:1 motor showing 136psi,... I'd be comtemplating a Tear-down,+ Rebuild....
Bondo,
You got bit by the old 4 year old thread again!
Damn,......:rolleyes:
I thought this was abit Exciting, considering I only left the keyboard long enough to go buy groceries....
Status
