fuel pump compatibility
tystick
will a carter fuel pump part #CARM60159 fit a mercruiser engine that calls for a #862077A 1 ?
Scaaty
Re: fuel pump compatibility
You need a MARINE PUMP..PEROID. There is a hell of a difference...called a fireball. NO substitutes.
tystick
They are both marine pumps. PERIOD
tommays
My merc pump is a carter :) but i have no idea about interchange
Tommays
The Sierra pump you would be looking for would be a 18-7284. That pump crosses to a Carter M60315.
Not sure what the number you have crosses to.
Scaaty
Then STATE that....give ALL the info. SAY its a Marine pump. Theres ALWAYS someone here trying to cut corners, and do something stupid. And just for kicks, your Screen-name refers to "dope", so what are we supposed to suspect? And being a smart a## will get you nowhere here, At least not with me anymore. Good Luck Tystick
]They are both marine pumps. PERIOD
[/quote]
Don S
google.com is such a wonderful thing.
Shame you don't have an 81-87 OMC 327 Chevy engine, your CARM60159 pump would be an exact replacement.
tystick
ok so ya wanta mix it up a bit?
Don't jump to conclusions if ya don't know what you are talking about
Don s I give all the props to but you ...keep smoking the pipe crazy
Don S
I have no idea what you mean by that statement, but if you re-read my prevoius post, you will find the CARM60159 part number you gave is for a 327 engine and is NOT a replacement for the Merc pump number you gave.
tystick
That is why i posted this as I am suspect to the claim that this is compatable as follows:
According to the ebasicpower, they are stating that it will work on all v6 mercruiser engines with mechcanical pumps.Could it be that they have matched it up somehow and can sell as such even if the parts book says it is for a 327 engine?
ps
it means full respect - an old boating term:)
tystick
Don said:
You must be seeing something at ebasic that I'm not seeing. The only thing I see that pump used for is the OMC 327.
http://bpi.ebasicpower.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=ebasicpower&Category_Code=ALL4C
And here is a link to their application chart.
http://bpi.ebasicpower.com/mm5/fuel_pumps.htm
Don,
here is link to item :
although they do not mention the actual part # here - they confirmed to me that it was a carm60159
and would fit all merc v6So now i am really confused :'(
http://cgi.ebay.com/ebaymotors/ws/e...m=320028284208&ih=011&sspagename=STRK:MEWA:IT
Don S
Then buy it, but when it doesn't fit, blame it on the one that gave you conflicting information from what there site provides. Things like that is exactly the reason I don't like ebay as a parts source.
tystick
Don,
we are talking about Ebasicpower not ebay. Ebay has nothing to do with it.They are only using ebay as a tool right?
Anyway, i gotcha as far as fitting or not but when a respected outsource provider of marine parts is behind it then i feel they should know what they are talking about.
Maybe they know something I don't
