Johnson 1994 3.3 hp low-end carb adjustment
johnson_lover
I rencently acquired a Johnson 1994 3.3 hp motor model number HJ3RERM. I put new plug, impeller, and lower unit oil in, and mixed up a fresh batch of 50:1 gas. It starts up in a couple of pulls and runs great on the top end. It will not run well under about 1/3 throttle. Moving the throttle to minimum (against the mechanical stop) will immediately kill the engine. It appears that it is lean as I can mix in a little choke to get a better low end run. It also needs a little choke to get a transition from low to high when cold. I diassembled and cleaned the carb and it was fine. I found no needle to adjust - just the low-end mechanical stop. Is there a way to get this kitten purring on the low end or a way to improve the transition? Thanks, JC d:)
D
DJ
Guest
Re: Johnson 1994 3.3 hp low-end carb adjustment
There is no low speed adjustable jet. It is fixed. The engine should kill when the throttle is against the stop.
I would clean the carb again. Pay special attention to any orifices. Carb cleaner and compressed air are necessary.
johnson_lover
OK, thanks for the advice. I'll clean her up again using some carb cleaner. How 'bout adjusting the float a little higher? Would that help?
JC
D
DJ
Guest
If it is set to spec. setting it higher will just make it flood.
johnson_lover
I cleaned carb and went fishing today. Fish bit, and motor ran well. d:)
It ran better on the low end after five minute WOT run to the fishing hole to come up to temp. Still not a tick-over idle, but perfectly acceptable.
Thanks for your help!
JC
