Galant Transmission
nothreat
I have a 2000 Mitsubishi Galant. I need to change the Automative Transmissio filter. I also have a Haynes manual for the 1995 -2000 Galant. I looked at the book and it seemed like this was a simple task and much like other cars I have worked on. When I ordered the filter I noticed it didn't look just like the picture in the Haynes, but it was pretty close so I ordered it. I got under my car today and could not find anyway to drain the transaxle pan. The Haynes shows it as a horizontal pan and in my car it is definitely mounted vertically and does not have the drain plug the picture shows. Has anyone ever done this? Do I just remove the pan mounting bolts and let the fluid run out in a mess? I guess I am going to have to get real shop manual, but I would like to get this done now. I am 60k over the normal change mileage. Any Mitsu owners out there?
Thanks
bandit86
Banned
Re: Galant Transmission
just remove the pan and seal it up with some quality automotive silicone
Bob_VT
Alot of pans lack drain holes,,,, common practice.
If you are 60K past the miles for the trans I would absolutely find a mitsu mechanic and talk with them. Some people have changed their fluid only to find the tranny starts to slip.
xtraham
check your service manual some of the import trannys have to be dissembled to replace the filter, if it is in the pan it's a very simple task, do not use silicone stick the gasket to the pan with a little weather strip adhesive, tighten the bolts to only where you see the gasket start to compress or the gasket will split and leak,
