Slow Speed Control
jeffnick
Boat Info:
Length =18 ft
Useage =Cruising
Top Speed =38 MPH
WOT rpm =5500
Current Pitch =17
I run a factory 15x17 3 blade aluminum OMC prop (391200) on my 2007 115 E-Tec. Performance is very acceptable overall, but I'd sacrifice some top end for enhanced slow speed manuvering and a better bite in reverse. I see there is a 4 blade Vortech @ 15X16; would this be worth a try? Or any other suggestions? Composite maybe?
Grodyman
Re: Slow Speed Control
I have had good luck with Merc High 5. I am currently going to try a Merc Alpha4 4 bld. aluminum because I want the characteristics you desire, and more bite in bad weather. In my experience, added blades give the results you wish, with some sacrifice of top speed. Vortech 4 bld should show improvement and be a good prop for cruising. If I had a smaller engine and wanted to maximize it's potential, I would opt for SS, then you get the benefit of extra bite from SS and from the added blade(s).
RT
Dhadley
What kind of hull is it? Is the motor set at a fairly high X dimension?
jeffnick
Don't know what an x dimension is, but here's a pic. She's a relatively heavy, moderately powered boat.
Dhadley
Good pic / info. I'd guess that just about any ss prop you try will be better than that prop. That boat will need a prop with some bow lift, it doesn't need stern lift at all. Something like the Stiletto. Even though it's a 14 1/4" diameter it'll bite harder than that prop.
jeffnick
I guess the pic is a little confusing...
The prop in the pic is a Hustler and is NOT the one I am refering to; it was only handy when the motor was put on. The prop I'm using is a 15 X 17 OMC 391200 3 blade aluminum. It is much better for slow speed control and backing than the Hustler.
The prop I'm considering is the 4 blade Vortex @ 15X16:
http://www.miwheel.com/MIWheel/products/outboard/vortex_4-blade.htm#vort4
Would this prop give me more slow speed control and better backing, or just less top end?
