Unusual propulsion system
Dunaruna
[colour=blue]Came across this little gem at my local marina. No reverse gear, the entire pod rotates to achieve reverse. Maybe not an earth shattering discovery except that - it was built in 1968!
rodbolt
Re: Unusual propulsion system
maybe its an optical illusion but I cant see enough fwd clearence for the pod to rotate 180+ degrees.
there used to be a fleeet in bayou Labatre AL with 2cylinder lathrops that just shut the engine down and restarted it the opposite rotation for reverseing.
I remember (vaguely) reading about this setup. Unfortunately that's all I remember. Reversing an engine was a cheap way to get reverse in that era. I was In Germany in the early 1960's and Messerschmit (sp) made a two seat (fore-aft) car that required switching off the engine, flipping a lever, and starting the engine in reverse to back out the driveway. Reverse the process to go forward. Looked like a coffin with a bubble top on wheels. No reason the technology wouldn't work in this application. A little slow to respond if you approached the dock a little quick.
Dunaruna
[colour=blue]I agree, it doesn't appear to be able to swing 180.
I have just found out who owns the boat, I'm hoping to take a much closer looksee next weekend.
rodbolt
man
that engine box looks like a nightmare from a maint standpoint.
I look fwd to more pics and information :).
danpemby
I could not imagine trying to wrench something in there. I guess we know why it never hit the mass market.
QC
There are some Ferries in British Columbia that operate like that. I was working on a Dual-Fuel repower for a pair of them that are already CNG now :% They hum along at 100% power and simply spin 'em around to stop . . .
salty87
does that whole red 'barrel' rotate? seems like that would be real tough on old hoses. not to mention take a bunch of room just for operating clearance.
plus, if that pod jams for whatever reason, you lose steering?
Mischief Managed
SkiDoo snowmobiles reverse the engine for reverse gear. Easy to do on a two stroke.
triman
Most ships are direct drive, that is the engine/shaft/propellor is one fixed unit. To go astern the engine is stopped and restarted backwards. Works with both the big 2 and 4 stroke diesels.
ziggy
i'm wondering if this isn't what's called a saildrive?
Dunaruna
[colour=blue]
It looks as though the red circle at the top is a fixed bracket for the pivot pin. The two radiator hoses look fixed - but I'm not sure.
The guy sitting on the swim platform assures me that it steers very well ( I showed a lot of scepticism!). It was manufactured by 'Ramsay Boats' in the 60's.
Dunaruna
[colour=blue]Nope, I'm wrong, the whole thing pivots.
