Hi all I am getting ready to take this thing to the river tomorrow to see if I have any real problems with the engine (see other post) and I put the new thermostat in and ran it on muffs. The temp gauge shows 180-190 and then cycles back to 180 as the stat opens. I feel the sender or gauge is wrong so while running I held a plastic container under the exhaust (spent cooling water) and had a thermometer in it and it read a constant 120* I guess the water would loose a little temp after leaving the block I guess maybe 15* so that would give me 135* The stat is a 140 so I feel it may be the gauge or sender. Is this a logical way to test the water temp? If not how else could I do it?
Thanks
Jim
Thanks
Jim
