imported_Captain Morgan
Thread starter- Joined
- Sep 13, 2006
- 42
I was playing with the trim up/down button while my 17' Wellcraft Classic was on the trailer today with the outdrive all the way up. The down button caused the drive to go down. When I pushed the up trim button, nothing happened. To get it back up I had to press the "trailer" button. It seems like something is not right. Someone told me that the trim only changes the drive a few degrees near the full down position. I couldn't get the drive all the way down because the bottom of the drive(keel I think it's called?) hits the street while trailered. Is this normal for the up trim button not to do anything unless the drive is already 100% down? It doesn't make any noise when pressed like the down trim button does.
If I do have a problem, where do I check first? Do I start at the switch and work my way electrically to the trim device? I'm taking the boat out for the 1st time tomorrow after buying it so hopefully everything will work okay. I still like to hear any thoughts on this matter when I return tomorrow. Thanks.
