owners manual, fuel mix and any other info
shasta lake
montgomery ward sea king 9.2 hp,
model VWB 29909A
serial 96x 10573
year made ?????
any info Ican get
steelespike
Re: owners manual, fuel mix and any other info
Is it possible that is 2790 That would be a 69 built by
Chrysler.It appears the 69 was the last year for the 9.2. Champion J4J plug at .030. Points set at .020.
24:1 fuel mix.Tillotson MT-97A carb.A Chrysler manual would serve you well.
if this engine has been sitting, go to the engine faq forum, and read "Awakening a sleeping outboard"
Paul Moir
Additional information:
Horsepower 9.2 brake HP at 4750 RPM
Engine two cycle two cylinder, alternate firing
Bore and stroke 2 1/8” x 1 11/16”
Displacement 11.97 Cu. In.
Carburetor Float feed
Connecting rod Forged Nickel Steel – Uncased needle bearings at crankshaft. Cased needle bearings at piston pin
Crankshaft Forged Nickel Steel. Cased upper Main and lower Main bearings. Bronze centre Main and thrust bearings
Propeller Aluminum alloy – 8 Dia. X 8 pitch, Right hand rotation
Cooling Water cooled – positive displacement type water pump
Transom height 15”
Weight 55 Lbs.
Fuel mixture 24:1 1/3 pint SAE 30 outboard engine oil to 1 gallon of regular gas – 85 octane
Avoid ‘Premium’ gasolines with 95 octane and antiknock additives
Recommended Operating range – 4000 – 5500 RPM
EDIT: Obviously nowadays you would use TC-W3 outboard oil instead of SAE 30 weight.
shasta lake
ARE YOU SAYING THIS IS A 1969 MODEL AND WHAT ABOUT 2790??
shasta lake
Transom height 15”
Weight 55 Lbs.
THANKS FOR THE INFO. DO YOU HAVE A MANFU. DATE
steelespike
You said your number was VWB 29909A I only find VWB 27909. My book doesn't list the prefix or sufix letters.prefix VWB indicates a West Bend or Chrysler built motor.Chrysler bought West Bend in 65 thus it
is a 69 9.2 hp.built by Chrysler based on their 9.9.Is it possible you miss read the number as 29909?
shasta lake
rechecked VWB 29909A it's correct. No other markings other than built by MW
shasta lake
ENGINE WAS SITTING FOR A LONG TIME BUT FOUND GOOD MECH. TO CHECK IT OUT. RAN FINE, PREVIOUS OWNER TOOK GOOD CARE OF IT. tHANKS FOR THE INFO.
Paul Moir
I was only able to find VWB 299091 ('69 9.2hp). Perhaps the fellow setting up the punches was a little off that day. Wouldn't be the first time! :)
Like any other outboard, it'll need it's impeller replaced every few seasons regardless of use. I'm sure tashasdaddy just didn't want you to ruin it by overheating.
