EricKems said:
So what does an engine do under a load that it doesn't do without a load?
More fuel which results in more heat and combustion pressure which results in better combustion.
Techno, think of your fuel injection pump (pump with a bunch of lines, right?) as a distributor. It has to be "initial" timed to the cam and crank combo. And then, like a distributor, it needs to advance in timing as speed and load increases. i.e. more fuel, needs to start earlier. On a pump and line system that is usually achieved by an advance on the drive gear for the injection pump. This may have some gears and flyweights and springs and stuff. This could be installed off a few degrees or stuck advanced.
None of this is still proper diagnostics. Sounds like we have eliminated compression, fuel (you seemed to indicate multiple tanks) and air, but I am not convinced we have eliminated heat although the white smoke at restart would seem to indicate we have.
I am still leaning toward timing and/or a dribbling injector at low idle delivery. Just things to think about. I am more inclined to think timing as it is isn't missing . . .
