Remote control box
Little.desperado
Hello Everybody,
can i use the remote control box from my 1989, 30 hp Evinrude on a 1985, 50hp VRO Johnson?
If i buy the new engine mentioned above, what do i have to watch at especially? The compression of the cylinders?...?
Thanks for your help!
Flo
Re: Remote control box
compression. spark. lower unit oil (water). look for obvious scaring on nuts and bolts (work that has been done and why) new paint ( What is it covering up? overheating?) as long as the electrical connection plug matches you should be ok. the conversion kit is almost as expensive as a new controller.
rickdb1boat
Remote will work....Good motors. I would make it a point to change the water pump impeller and lower unit fluid right away...Personally, I would pre-mix until I verified that the VRO (If still connected) is working....
