Rabbitdawghunter
Thread starter- Joined
- Jun 20, 2003
- 147
Have a 2002 Suzuki 50 HP 4 stroke. Engine would not crank. SDS software indicated CKP sensor fault. Monitor agreed with the software , flashing 4-2. I replaced the crankshaft position sensor (the later single style). The engine cranked up and runs fine . The monitor still continues to flash and sound the same code, from what I read in my notes it is supposed to clear itself when the cause of the fault is corrected and the engine is run. That is not happening. I am thinking that the air gap is wrong. Does someone have the correct specification for this. Other ideas openly entertained, thanks?
