Re: 1992 Evinrude-no spark- not the kill switch
The pins in the rubber connectors will push out and back in.... no need to cut wires.
Reconnect that black/yellow wire that you cut. Remove the spark plugs so that you will obtain the fastest cranking speed possible. Rig a spark tester whereas you can set a 7/16" gap. Home made rig follows.
Spark Tester - Home Made
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a couple nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
Crank the engine by using a small jumper wire from the battery terminal of the starter solenoid to the small 3/8" hex nut that energizes it (Not the 3/8" hex ground terminal).
Reason for removing the plugs.... the engine must turn over at least 300 rpm in order for the stator to supply approximately 300 AC volts to the powerpack capacitor. A slow cranking engine would fail to supply that voltage.
With everything connected, I assume that you have no ignition (spark). disconnect that large RED electrical plug at the engine, then retest for spark using the jumper wire at the starter solenoid.
If still no spark, and the engine is cranking at the proper speed, look under the flywheel at the stator. If it is cracked and/or dripping a sticky substance down on the timer base and powerhead, replace it as in that condition the voltage to the powerpack will be insufficent.
If the stator is okay (and you're sure of that), and you still have no spark, in all probability the powerpack can be suspect.
