FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
The gear oil turns white when mixed with water. This may be a worn seal or a crack in the gear case. You may want to drain all the oil, pump about 7 psi of air into the gear case and submerge in water to look for the leak.
Yes that is definitely water. If it is very milky white then a lower leg unit reseal is in order before it destroys your gears with corrosion and then eventually failure of the lower unit.
Before you go nuts with this buy new seals for the fill and drain plug and refil with fresh oil. This is the most common source of leaks. Check often for water & if it turns white as the others have mentioned follow their advice.
