This motor had a complete power head rebuild back in May. The power pack was just replaced about 1 month ago and spark plug wires were replaced. The coils were not. Motor seems to run good and has plenty of power. Noticed that when I changed the plugs the plug on the lower port cylinder was very clean and appeared to have moisture in it.
Compression is around 120psi cold and 100 at warm operating temp. I have noticed that when running around 4000rpm's that every now and then it might drop to 3800 for a second and then pick back up. Does it sound like an ignition issue in that cylinder? Thanks for the advice in advance.
