Reel Poor
- Joined
- Jan 29, 2005
- 5,522
Re: difficult starting
That should not affect the system operation.
Are you still chasing this problem?
Question.....Why are you guessing? Do you have a timming light with a manual advance degree knob on it? If not, you can't properly check timming advance.
As for the knock sensor.....It would only stop spark advance if it was shorted to ground, sensing a knock, or the blue wire is routed to close to spark plug wires.
You can check the sensor with an ohm meter for short to ground.....check the blue wire routing......if your still running the 87 octane fuel this would also cause your problem.....Your engine is running to much compression for 87 octane fuel you NEED 92 or 93 octane.
With the proper timming light, and the right fuel in the engine, you can disconnect the blue wire from the sensor and see if the timming is advancing properly (boat should be in the water and run under a load). If it's not, I would suspect a faulty ignition module. With voltage present on the purple /white wire (and it's definately getting to the Ignition Control Module, check both module terminal plugs for corrosion) and the knock sensor disconnected, the timming should work properly. WARNING: DO NOT CONTINUE TO OPERATE ENGING WITH KNOCK SENSOR DISCONNECTED
Also, be sure both modules are properly grounded, they have both wire and case grounds.
When I checked the voltage at the Ignition control module it showed 10 -12 volts at the Purple/white timming lead not 8-10 like the manual says
took engine to 3000 rpm advance appears to only pick up 5-10 deg Im guessing.
