I am going to be replacing the gearcase seals and the impeller on my force 35 hp outboard (1988). The gear case was taking in water due to (I think) a bad prop shaft seal. Question is, can anyone tell me how far the bearing holders need to be pressed into the lower unit housing?? Is it until they are flush with the outside surface??? Is it difficult to get the pin in to hold the shift yoke? Any last minute help I need??? I have the manual so it shouldn't be too bad...I hope
