165 hp 3.7l won't start
sailorkeith
Hi all,
I need help I just bought an 87 sea ray saville with a 165hp mecruiser. I've replaced the starter, the slave solinoid, and the ignition switch. When I turn the key the volt meter drops from 14v to 12.5v but not so much as a click from the soliniod. If I jump from the battery to the starter terminal the engine cranks over. I confused:'(
JUSTINTIME
Re: 165 hp 3.7l won't start
check nutral safty switch
stop switch
make sure u are not in gear
sailorkeith
I know it's not in gear and the nutral safety switch appears to be in the correct position. Is the stop switch the circuit breaker? I think it might have popped I push on it hard but I'm not sure it's resetting.
Don S
sailorkeith
Thanks Don this was exactly what I needed. I'm heading out to trouble shoot nowd:)
sailorkeith
Should the propeller turn freely in both dirrections when in nutral?
