Hi,
1999 Merc 4.3 I/O
The past 2 seasons, I notice that I am leaving a pretty large oil slick on the surface of the water whenever I leave and enter my dock.
Over the span of the season, I lose no crankcase oil, no stern drive gear oil, but I have to add about 1 pint of trim fluid (I use power steering fluid) during the season.
So, I'm pretty sure the power trim system is the culprit, but do not know where to start checking for the leak when I take the boat out of the water for the season.
It does not leave any leaks on the ground when out of the water.
Do I just replace the trim cyliners, or are there o-rings and gaskets that I can replace as a cheaper first step? Ideally, are there good checks that I can perform to identify the actual source of the leak?
Thank you very much for any sugggestions.
1999 Merc 4.3 I/O
