Hello
Last year we picked up a boat with I believe a '73 Merc 850. Had it checked out, new water pump/impeller, clean carbs, etc. Ran great. At end of season I winterized it and the lube I replaced looked great, no signs of water, etc.
This year, I had the boat out about 6-7 times with no problems, before getting a new boat, so this one sat. My father decided about a month ago that he wanted to take this fishing for a weekend.
I told him to take it (I was up north at the time) but to check a few things including to check the gear lube. Well, as I've learned recently, he apparently removed the lower plug, and when the lube came pouring out, quickly replaced it. He didn't see any problem and just lost a bit so he went with it. Said he only ran it about 10-15 minutes or so to get where he need to go, then used the 20hp troller for the idle work.
So, here I am, in the process of winterizing it... I remove the lower plug, and get about 2 tablespoons of water. I immediately notice THERE IS NO GASKET on the lower plug!! The oil continued to come out with a slight mixture of water, then thicker. It doesn't look/smell burned, nor do I see any metal fragments. I also noticed there was less lube than there should have been coming out - meaning, noticeable, maybe a couple ounces.
So, now I'm wondering, what are the chances of damage? Is it likely that the water got in due to the missing gasket? Does the lack of fragments/no burning mean it may be OK??
I'd like to be able to sell this thing next year, and now I feel like I need to get it checked out.
Thanks
Thanks
