Re: LU oil looks like chocolate milk
If you plan to continue using that dealer, you might want to consider asking him about the missing gasket and gauge his response. Personally I'm usually willing to overlook an occasional mistake as long as the other party owns up to it.
Runout is just the measure of how bent the propeller shaft is. It's normally measured with what is called a "dial indicator" as the tolerance is just a few thousands of an inch.
But you cannot hope to measure it without first removing the propeller as the propeller could be unbalanced, the rubber hub could be somehow off, etc.
I hope to hell (odd expression, eh?) that you don't have any side to side play in the propshaft. That can be caused by insufficient lubrication.
