Johnson control box - 3 pin connector
firemann2003
does anybody know where i might be able to find and buy the 3 pin connector that plugs into the control box?
firemann2003
Re: Johnson control box - 3 pin connector
They don't show it on the engine diagrams.
OBJ
If you are talking about the tach connection, you can get the harness from any BRP dealer or there are aftermarket ones also. The BRP part number is 174732.
EDIT: You can find the harness at the BRP site by choosing O/B Accessories and Instruments under that catagory. Harness runs about $30 from BRP.
firemann2003
Thank you OBJ, found the harness I was looking for.
michiganmarty
Ok, pardon my ignorance here, but who is BRP and what is their web site?
ezeke
BRP is Bombardier Recreational Products, successor to OMC after the bankruptcy.
They have been kind enough to post parts manuals for most of the outboards since 1968.
Unfortunately, they don't sell parts at retail. But,you can get the part numbers and that is a huge help.
Copy the link to your browser, without the quotation marks:
"http://epc.brp.com/default.aspx?brands=ej&lang=E"
If you wish, you can download the parts lists to Excel and print the parts diagram, so that you will have a hard copy of your parts manual.
Cabela's has them.
WTPhantom309
ive got a question about that connector myself. i know the grey wire goes to the tach but where do the other 2 go? pardon my ignorance, cant find it in the seloc manual
Thanks for any help
Derek
ezeke
Many of the controls with the tachometer plug were wired
like this:
The grey wire connects to the "S" on the tachometer and to the grey wire in the wiring harness, which runs to the terminal block on the engine;
The Purple wire connects to the "I" on the tach and runs to the positive terminal "A" on the ignition switch so that the tach is off when the ignition is off;
The Black wire runs to Ground on the tach and common ground "M" on the ignition switch.
Grey -------> O
Purple + -> O O <- -Negative Black
http://www.iboats.com/mall/index.cg...164616625&session_id=876585926&view_id=169183
WTPhantom309
Thanks i got my tach goin I had it connected right but found the pin was broken off the puple wire thought i fried my tach thanks a million you guys rock
Derek
