Re: Should I add Power Trim?
Seldom is one able to have the best running angle on the engine with manual tilt.
Reason being is that the best WOT engine attitude would cause problems at the lower speeds...like porposing or horrible hole shot.
If you are able to run your boat without the above problems, it says that you are in for some more mph, maybe the 5 you are looking for by installing trim.
If you answered yes to the previous paragraph you have told me (by definition) that you are "plowing" at WOT and when you lift the bow outta da watta you'll get your speed...............but not with an alum prop!
If you are going to get some serious speed out of that rig you need a serious prop.....in particular, a prop with thin blades among other things like cupping and high rake and all that tech stuff. BTDT....and I used to run an early 80's 85 4 banger with PTT.....but 39 was the best I could do.....but I could have spent some money on props and done better. At the time, was lucky to have a boat at all. d
......and, thanks to Kenny and iboats, I know a lot more about them now than I did then.
I just ran over to the prop slip calculator and plugged in your numbers and it said that at WOT your prop slip is somewhere between 26 and 36%.........horrible.
This says 2 things; your prop is letting you down and you are plowing which is putting extra pressure on the prop which adds to the slippage. I don't remember the gear ratio for that engine but I used 2.3:1 (26%) and 2:1 (36%). The lower the ratio the worse it gets.
So, this supports what I told you.
I put in some hypothetical numbers. Said you had a 2.3 ratio (lower ratio would yield better numbers). Said that you would pick up 300 rpms by getting the bow up which significantly reduces hull wetted area and hence drag....not hard to do.....now WOT is 5600 rpms.
Stayed with 21p but this piece of data is based upon (your getting) a high performance SS prop.....this allowed me to gustimate the slip down where it belongs at say, 12%.
That put you at 42 mph. That what you're looking for?
My 2c,
Mark
