FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Is it common practice or a good idea to seal outboard mounting bolt holes and thru-hull fittings with something like resin or Gluvit before installing and siliconing? seems like it would be a good idea but this newbie knows it's better to ask first.
The 5200 is made by 3M and is good below and above the water line. It comes in a squeeze tube or in a caulking gun tube. Don't use silicone it does not adhere well and eventually will let water in.
Make sure that the epoxy is dry before using the 3M 5200 .
I guess I was talking more about using a hard resin type product (and letting it fully cure) before adding the softer bolt sealant (5200, 4200) and hardware. My thought was if you used a product like Gluvit to seal the actual wood then if water does make it's way into the bolt hole then at least the water can't be absorbed into the wood.
