keith horne
Thread starter- Joined
- Oct 12, 2006
- 11
I have a question about max rpms. I have a 1986 140hp looper on a 1987 19.8f chaparral sorry but dont know the weight of the boat. But what full throttle rpms should this engine run at i have four props to dail in with one is a 13.75 x 15 omc aluminum prop boat will snap you head back when taking off runs at 6000 rpms other is same as above oem but stainless steel but needs to be reconditioned but should be about the same or a little bit better other is a hustler13.25 x 17 aluminum lost little out of hole turns about 5500 rpms speedo says about 43mph trimmed out wish i had gps maybe down the road but anyway last prop is a cabelo's 12.75 x 19 stainless steel comes out of hole like a dog runs at 5100 rpms all props seem about same speed??? would think there would be a bigger difference also bottom of boat has no paint and like new i also always wax it every spring and at end of season i am a little nuts i know but i take care of what i have work to hard for the little i have. Can anyone tell me what rpms is best and maybe which prop to use and last what maxum speed should i get thanks keith p.s gave all the info i have.
