imported_Kiowa
- Joined
- Oct 26, 2006
- 2
I recently purchased a 2000 Evinrude 9.9 HP outboard motor (came with mini pontoon). It is a four stroke, 305 cc. My question involves winterzing the motor. It will stay outside during the winter. The local resort owner takes care of most pontoons on our small lake and took the boat out of the water for me. He added stabilizer to the fuel tank prior to loading it on the trailer....drove it around the lake for about 20 minutes before loading it so the stabilizer had a chance to run throughout the motor. He checked the lower gear lube and determined it was okay....no water appeared to be in it. Then he opened up the hood and was going to pull the plugs and spray fogging oil in them and then replace them. However, he did not have the necessary tools....spark plug wrench. He promised to return to complete the job once he found the correct tools, however, I fear I am low priority on his list as he has many other boats to service, and has not been back for weeks.
My question is.....is it necessary to pull the spark plugs and spray them with fogging oil? Also, can you tell me how to remove the plug that is in the bottom area? There is one plug that is easily accessible, but the other one is down lower and appears to be really hard to get to. Do you have to remove part of the housing to get to it?
Another concern I have is whether the gas can and battery should be left on the boat during the winter. Filling the gas can to cut down on condensation I know should be done. Should I take the battery off and store in the house? Also, should I tilt the motor and cover it to prevent snow getting on it.
I have read many posts on the message board and have a good idea of how to winterize an outboard motor....but the few remaining questions above still have me wondering.
I'm somewhat mechanically inclined and know my way around a screw driver and wrench, as I build and repair computers. So I'm sure I can pull the plugs if I need to and perform the other tasks.
I'm new at this and appreciate any and all help. Thanks.
