question about flywheel removal
jujubean
on my 95 mercury (25 hp) my flywheel has some phillips screws beneath it. Will the whole thing come off togethor with a puller? or do I need to remove the phillips screws first?
jujubean
Re: question about flywheel removal
So I just leave them screwed in to take the flywheel off right?
JUSTINTIME
yes just take off the center nut/bolt and use a puller
do not use a hammer on flywheel, and do not put it on a metal surface, do not drop it either
jujubean
ok, I'll be taking th flywheel off today. Is there anything I should do once it is off to check the trigger to see for sure that its the problem?
In other words, what would you do once it was off? Thanks!
BTW: You know I am the same post your answering below right?
JUSTINTIME
yes a just figured the double post out
pull it and we can do a better testing
jujubean
O.K., I'll try to get it off this evening and have some details on here tomorrow. Anything else I should do you think?
JUSTINTIME
no we will go from there after testing off motor
Wouldn't it be a good idea to tell us "why" you think the flywheel needs to be removed? If the engine won't start, that's certainly not the first thing to come apart! Give us some details.
Would be helpful to state that. If was stated in another thread it is also helpful to keep one thread going rather than having us do the searching.
jujubean
Sorry about that, it was my fault. Yea, I need to take the flywheel off to replace the trigger. I'll be doing it this afternoon. Hopefully it is grounding or something and I can fix it without having to buy one, but I doubt it.
Sorry again.:'(
