Re: cant ajust trim...drive ratio....rpm of motor
Welcome to iboats gregcb12!! Here's some info on posting a picture:
How to post a picture
Also, since you are trying to figure out how to run her etc. If those prop dings are pretty small, clean them up with a file or you can even use vice grips to straighten tiny little wiggles out. Then try the top speed thing again. If the dings are half the size of a dime or bigger, it is probably time to have somebody work on it.
If you can't get the boat to "porpoise" (rhythmic bouncing of the bow up and down) at your highest trim setting, then I would try shifting some weight aft. You may get more speed and RPM at the point just before she starts to porpoise, but if she won't porpoise at all there may too much weight forward to get all the speed she has. As Don is telling you, we need to determine if the prop is correct by noting the max RPM at WOT, trimmed for the fastest you can go AND with a typical load in the boat. Ya know, fuel, beer, people, more beer, maybe some food, toys etc. Definitely get rid of any excess weight you can, but she needs to be propped for how you will use her most of the time. Based on your top speed that you reported, I think it is pretty close, but the fact is she may be more responsive and possibly faster with less propeller pitch and some more RPM, I wouldn't do anything until you're sure that your getting all you've got though. This is the part where you might get to spend more $ . . .
