FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I want to install a temp gauge(non digital) on my 17ft center console. Where is the best place to put the temp sensor wire on my 1996 88hp Johnson O/B?
The wire goes wherever you put the temp sensor. They come in three varieties 1) screw into the water jacket if a threaded port is available, 2) thermocouple under a head bolt, and 3) on a bracket that allows the sender to touch the cylinder head. The sender needs to match the gauge.
The water pressure gauge is a good indicator of water pump performance but will not tell you that the water is actually going through all of the cooling passages of the engine.
The temperature gauge is a good indicator of the thermostat performance and of the water pump performance and will give the attentive operator a heads up long before the engine overheats, which the horn sender will not do.
The temperature gauge will tell you if you are running too cold as well.
