Emerald14
Thread starter- Joined
- Feb 21, 2006
- 31
Hey all
My 1968 18hp evinrude runs like a champ, especially after all the help I received from this forum.
Thanks
With that said...I use the motor for trolling the local trout lakes with my two boys. After an hour or two after low rpm trolling, I usually take the motor out of gear and throttle up the rpms. My logic is that I'll "blow out" whatever may build up to make the idle rough. Probably not a scientific theory. When I do this, most of the time there is a whitish oily sludge that comes out of the exhaust. Just curious if this is normal...
Also...sometimes when were trolling(rpms are bottomed out) the motor will just die. No sputtering or coughing it will just die out. I've tweaked with the low idle rpms and mixture to improve it a little, but every now and then it will happen.
I use the motor about once or twice a month. If I don't get it out on the lake I will run it in a barrell just to keep things fresh. I use fuel stabilizer and dont bother to disconnect the fuel line. Figured there was less chance of contamination if I kept the line attached. Any maintenance advice for me to consider???
Thanks again
JR
Thanks
Thanks again
JR
