attwood battery switch, good piece?
JUSTINTIME
Re: attwood battery switch, good piece?
it will only charge the battery u have selected
these switch's are good but watch the rated amps, the more the better
the best way is buy a isolator then go to the switch this way both batteries charge
Boatin Bob
The switch will work, with an isolator or combiner it's better. Make sure the switch is a "make before break" so that if needed you can switch it from 12 or both while the engine is running however, NEVER turn it to off while running or you will toast the regulator in the alternator. This link will show you a few wiring samples, Look at B andC on page 1 and D on page 2.
http://www.homestead.com/dolphinmarineservice/Ele1.html
