imported_rosco
- Joined
- Oct 12, 2006
- 68
well, any EFI / MPI fuel delivery workaround.
after weeks of searching i found this company.
http://www.weldonracing.com/
they make a pump that will pull fuel past anti-siphon valves and fuel filter / water seperators as well as pump out 45 PSI all day long.
what does what mean?
it means you can unbolt all that Mercuiser crap starting at the mechanical fuel pump, the VST fuel bowl, the fuel bowl cooling system, the 500 dollar "special" mercruiser high pressure pump, and toss them in the garbage.
and replace it with a single pump mounted anywhere past the fuel filter.
what you have left is "1" fuel pump, a fuel rail, and the fuel injectors. a cleaner, simpler system for about 1/5th the cost.
i plan on mounting the fuel filter and pump on the firewall, right next to the haylon system (heh), and having nothing on the engine except the fuel rail and 2 lines, the feed and the return line, of which both will be made from high pressure hydrolic lines with bolt on fittings. mercruiser can kiss my butt if they think im going to pay 500 dollars for a fuel pump and 75 dollars for a rubber O-ring just because they are the only ones who sell it. and my "mercruiser authorized" mechanic can kiss my butt if he thinks im going to pay him to toss parts at my boat untill he hits a bulls eye.
if your having problems with your EFI system, and your sure its not the injectors, this pump and a couple fuel lines you can have made at NAPA auto parts will solve EVERY other problem except the pressure regulator on the fuel rail.
your welcome. complimets of my mechanic who thinks "diagnostics" is the same as "replace stuff till it works".
