spark plug # 2 still new???
wilde1j
Re: spark plug # 2 still new???
Water's getting into that cylinder.
Walker
Probably just not getting any fuel. What engine are we talking about here?
iwombat
How long have you been running all these plugs? A super-clean plug may indicate a water leaky head (or other) gasket
F_R
1st thing 1st. Check compression. #2 could have a serious problem and just going along for the ride.
Cricket Too
I'm assuming it's 3 cylinder, like a 60 or 70hp, correct? Year and model are gonna help out a lot more, but I think that the 3 cylinders at least some models are prone to running lean on that middle cylinder. But that's a carb issue. If that plug is completely clean, it's probably water. Do you have white smoke out of your exhaust?
Definitely check that compression and see what shape that cylinder is in.
h_lankford
wait a minute
"plugs #1,3 are burnt, # 2 plug still looks new"
do you mean normally burnt or abnormally burnt?
everyone is jumping on the new-looking plug (that indeed sounds like steam cleaning) but is it opposite of what it seems,ie, the problem is 1,3 and not 2.
imported_newbieboater
sorry guys new at this forum you can check my other post also to give you guys more info...sorry tanx for all the help.
78, 70 hp jonhson cuts out when put on F or R please help
Solittle
You will get your best response by sticking to your first post. You have been given a couple of suggestions and I think if you follow them you will find the problem.
