Re: Also one last question, where is the blocking diode located?? J225TXCUB
You have to go thru the service manual troubleshooting steps to find out what is wrong with your ignition. Pokin', hopin', and buyin' is the long expensive way of solving your problem.
Erractic spark is not always a sign of bad diodes, plus both packs would have to be bad. Usually a bad blocking diode inside a pack will affect the spark from the good pack.
The manual tells how to test the diodes.
