2003 15hp YAMAHA 4 stroke
sharkman
Hello. Is there a special tool to remove spark plugs from this engine? I cannot get the #2 (lower) plug out as the socket (long 18mm) gets jammed against the block...thanks
No worries with the #1, its out
Mark
rodbolt
Re: 2003 15hp YAMAHA 4 stroke
nope, I just grind down the socket till it fits.
JUSTINTIME
try loosen and get your fingers in there
if that does not work, loosen a little and get some silicon tube to fit over the plug so u can turn it with the tube
