Fishermark
- Joined
- Oct 19, 2003
- 5,617
I have an SEI 106 outdrive (clone of the Alpha 1, first gen). I noticed when I flushed the engine after fishing last time out that there was no water coming from the outdrive.
(Just a quick explanation. I have a 2003 5.7 Mercruiser with a raw water pump attached to the engine with a thru hull pick up. This is the main cooling for the engine. The impeller in the outdrive merely goes up through the outdrive, through the transom assembly and is then routed back through the stern. The only purpose this serves is to cool the outdrive).
Anyway, I noticed it was pumping out water out through the transom while under way - just when I got back to the house did I notice no water coming out while on muffs.
I separated the lower unit from the upper and found the following: The plastic tube which connects the water pipe was melted.
Here's a couple more pictures:
I will be putting on a new impeller, as it is due, but as you can see, the vanes are all intact. What would cause this to happen? More importantly, what should I do to keep it from happening in the future?
