Just Purchased a Neglected 98' Wellcraft 2800. Need punch list
sail2steam
I just purchased a 1998 2800 Martinique. The boat has sat in the slip for about 2 yrs. I have scheduled a complete checkup by the harbor mechanic. Could anyone help me compile a punch list of things that should be done? I'm sure he will know what to do but I want to make sure he checks it all. My list so far includes: oil and filter change
coolant flush
replace impellers in outdrives
remove old gas if possible
replace bad batteries if needed (it will be)
test run
I'm still thinkin...
Reel Poor
Re: Just Purchased a Neglected 98' Wellcraft 2800. Need punch list
What engine and drive set up? Mercruiser or Volvo Penta
sail2steam
It has dual Volvo Pentas. The engine compartment is the cleanest part of the boat. The outdrives have been sitting there (fresh water) for 2 years and are covered in algae. The previous owner took the boat out a couple dozen times or so since 2001 and it was not even run or serviced since AUG 05. The boat only has 190 hrs (showing) on the counter. I really want to get this initial service right before I get out there.
Tail_Gunner
Clean the hull
Repaint the hull ((bottom paint)
buff the entire boat
change the oil
take her out and find your maz speed at wide open throttle, go to prop forums post and invest some more
take a trip to saayyyy somewhere mexico.......time to relax
get a good or perhap's several bottle's of your favorite wine or beverage for your maiden voyage
plan a trip
hunker down and dream.................. and just be ready.
Congrats..............8)
Reel Poor
This should probably be moved to the "Mercruiser, Volvo and OMC I/O or Inboard Engine Problems" forum.
Most if not all of these things listed should be done annually.
If the boat is still in the water it should be hauled out.
Check and repair or replace where needed
thru hulls
bottom paint
if freshwater boat only, anodes should be magnesium
Pull the drives check, repair, or replace where needed
all bellows and inlet water hose
gimble bearings
engine alignment
grease u-joints
grease input shaft splines
pressure test drives
change gear lube
remove prop and grease prop shaft
anodes (magnesium freshwater, aluminum brackishwater, zinc saltwater)
Engines check, repair, or replace where needed
raw water pump; it's belt driven, not in the drive
all rubber componants; boots, belts, and hoses
rust free belt pullys
manifolds and risers
oil and filter
fuel filter(s) may be one in the carb also
thermostats 160*
engine compression test
spark plugs, dist cap, rotor, plug wires
flame arrestor
batteries
battery cables, positive and negative at both ends
electrical connectors; all tight, and no corrosion on terminals
fluid levels; power steering, tilt and trim, trim tab
lube/grease steering tiebar connections
onboard safety systems check, repair, or replace
bildge blowers and hoses
bildge pumps and hoses
fire extinguishers
lights
horn
fuse holders, corrosion free
Note, for canvas snaps and corrosion prevention,
"Corrosion X" works great.
steering serviced. controls.
drewmitch44
Dont forget the canooter valve and the muffler bearings!!
sail2steam
Great Responses...Keep em coming! I guess this thread could have been put in the engine forum. However, my punch list is not limited to engines. Thanks for the help guys! Drewmitch44, when I get that canooter valve checked, I'll be happy to take you for a nice snipe hunt.
alden135
Canooter valves are best serviced with a bucket of steam.
Be sure to bring a left handed smoke shifter when you guys try to flush out those snipes.d:)
Solittle
Start by getting a good marine insurance policy if you don't have one already. Another would be to make sure that you have plenty of room on your credit card.
sail2steam
got the insurance as soon as I got home. however, the card is in great peril
John_S
I didn't see listed having the floor, stringers, and transom inspected for rot. It would be a concern with a moored boat that had tops that leak and any water sat inside for a time. Floor repair can take on a life of its own.
SwampNut
SURVEY!
The harbor mechanic is biased (wants to make money) and is probably not qualified to fully inspect a boat.
A surveyor works for YOU, and makes his money whether the boat needs work or not. He will give you a detailed written report of everything. If you do the survey with him, you will learn a LOT about your boat that you may not know. He will find details like out-of-spec little details that a marine mechanic would just overlook (or not look at to start with).
sail2steam
Get this...after I paid the guy for the boat, I also paid the marina over $3k with a verbal agreement (if I get their money I could keep the slip). Last day of Nov I went to sign the lease and pay the guy's slip as of 11/06. They wanted to put me in another smaller slip. Long and short of it... I have moved across the lake and ordered a trailer but not before getting the cell number of the mechanic who knew I got a raw deal. He said he would be happy to help me shadetree
stevieray
Hopefully, is boat located an area that doesn't ever get freezing temperatures? Can't believe nobody asked you this before now.
sail2steam
I'm in the deep south but even here it has been very cold. The first thing that I did was put in a light bulb and I ran a cord from my neighbor's power. I have now got my own meter and two XTreme Bilge Heaters. I put one in the engine compartment and one in the compartment with the waterpump/ hotwater heater. The mechinic is coming over to help me next weekend in my new slip. I have tested most of the equipment and eveything seems to be in working order other than one of the outdrive trims.
Nova II 260
LOL drewmitch44:
Everyone knows Canooter valves are only in the Canadian models.
