Stringer hose connection safe for water-pump?
hcwiii
I've been working on a 1966 OMC Stringer, trying to bring it back to life from the corn-field that it spent last winter in.
This summer, to try to determine what I was in for, I ran the engine a few times on the trailer, with the garden hose hooked up to the Flush adapter on the drive-unit pivot end-cap. I understood that the water flow was necessary to keep the lower-unit water pump from burning out.
I wasn't able to find many details about using this hose adapter for this purpose, but what I found said that, while the engine was running, to simply keep a steady stream of water coming out the exhaust and the tattle-tale holes. Is this correct?
Now I see, according to the OMC Service Manual cooling system section, the water-flow diagram shows the water going up and forward, from the vertical-drive and into the engine.
My question regarding this is, how does the Flush-it hose-hook-up keep the lower-unit pump from burning out if, at the Flush-it location, the water-flow is away from the pump and into the engine? ie the water goes toward the engine at that point in the system, and eventually goes right on out via the exhaust.
Also, if I or a previous owner has already burned out this pump (knock on wood), what indicator would I have before the boat went into the water? Do I have to stick it into a drum of water to see if it still pumps, or does the hose hookup method reveal something?
I appreciate any light anyone can shed on this for me.
KaGee
Re: Stringer hose connection safe for water-pump?
There is plenty of flow back to keep the impeller safe. The flush coupler is one of the best accessories for the Stringer.
wire knot
hcwiii,
The LU pump forces water up in the dirc. noted in the man. But when you attach to the flush fitting water can go both ways.
Make sure you see water coming from the picup tube.
before starting motor.
I believe you will not have a accurate indication
(in the yard) of your pump condition, untill you run
her in a barrel. You can force all kinds of cooling water
to the engine w/household water pressure.
I now have a stringer ('75-225hp) that cools great
on the hose, but at idle in the water she runs a little hot.
Hope this helps.
Boomyal
Best thing since duct tape, huh KG?8) No mickey mouse black anchors here...well, er, uh I mean....;)
hcwiii
Thanks guys, that helps a lot.
Now I just have to wait til the weather warms up a bit... It will warm up a bit, I know it will... It's got to!
BRG25
In NY? You're kidding right? d:) I hope your boat is winterized...
QC
Couldn't you determine that your LU pump was working well by doing a quick test with muffs? Seems like it would be a lot easier than the barrell deal.
BTW I have read a couple of times here (OBs too) questions about an overheat in the barrell. Don't you gurantee an overheat by using a barrell with no constant flow of cool water? ;) Sorry for the hijack but this one cracks me up. It has to eventually overheat once the thermostat opens . . .
KaGee
He doesn't need muffs or a barrell... he has the flush adapter!
Ditto on the winterizing... hope you drained the block and the manifolds after testing.
hcwiii
Well, yeah I drained the engine when I pulled it to work on the rod & main bearings. I thought I'd get the engine out of the barn and back in the boat before the snow. It probably would have been easier to 'winterize' on the stand in the barn.
I'm trusting the lower-unit pump drains itself hanging in the down position, correct?
Re: overheating in the barrel... I imagine I can get it warmed up, StaBil-ized, fogged, and shut down before it overheats in the barrel, don't you think? If not, I suppose I can hook up the garden hose again. Heck it's only 35deg out -- balmy! (Maybe I'm balmy)
I appreciate all the pointers guys, I'm a bit of a greenhorn with this home-care trailered-boat thing. My only other experience with 'winterizing' a boat has been leaving my friend's boat at the marina for them to deal with for the winter. Oh, and there was the 1950's Evinrude 15hp that I simply put a few squirts of oil in the cylinder to winter over....
'Sides, winter doesn't start til December 21st, eh? :/
KaGee
The leg is self draining in the down position.
QC
Sorry didn't mean to hijack or send in the wrong direction, I was basically commenting on wire knots assertion that the pump coindition could not be determined. I know what the hose adpater does . . .
wire knot
Muffs will not work on these units.
The water-picup faces down just forward of the
trim tab.
Yes she will begin to overheat in a barrel.
Keep an eye on the temp guage.
HCWiii asked about checking the water pp output.
I dont think you can tell w/a hose.
I am a new I/O owner. Not an expert.
I have not found alot of interest here for the OMC.
Simply trying to fill a gap with some experiance I have had w/ the cooling system, in the last 4 mounths.
hcwiii
There! I said it would warm up, eh? I only need one layer of long-johns today! Now if I can just get this done before it rains...
hcwiii
(deleted)
hcwiii
(deleted)
(how can I delete a previous post? :/ )
hcwiii
Lyndy said:
(snipped for brevity)
Check and make sure your browser is allowing Web Scripts and choose the yellow picture with the sun and mountains in it.
got it - thanks
Boomyal
Wire knot, that is because OMC's, at least stringers, are not the barrel of problems that Mercs are. If one get's their ego out of the way, you can see the difference in complexity between the two and thereby why there is so much to break down on the black anchors.
There are a few of us who are interested in the OMC's just that, because of their relative simplicity, they do not consume us.8)
The beauty of the OMC is that you do not go to bed at night and have nightmares about upper and lower cables, gimbals, gimbal bearings, u-joints, bellows, trim pumps, limit switches.....oh, my heart rate is starting to rise....:p
KaGee
Take a deep breath Boomer! 8)
Hey Wire... we're here for ya!
