Lubrication - throttle and shift linkage
jal
Along with lubricating the linkage, should the cables also be lubed with something like tri-flo.
Thanks
Walker
Re: Lubrication - throttle and shift linkage
If you can get any lube inside the cable sheath go for it.
JUSTINTIME
try corrosion block or corrosion x
u can buy a cable lubber from motorcycle shops
jal
Justintime, thank you.
What is corrosin block or corrosion x and is this worth the time and effort to do?
rickdb1boat
I think that by the time they need lubing, it's time for new ones...
