I have finally got my Winky-Blinky tester from Yamaha for $115.00 for use in testing my SX225TURY. Problems-WOT Cut outs, poor idle.
Hope this is not a repeat but I did search in the archives /files and only found the following regarding the Winky-Blinky's use " the tune-up spec guide is like 5 bucks and has all the codes in it."
Where do I get the Tune Up Spec Guide?
Is the information posted anywhere on the internet for
free access?
I've got raw gas running out the exhaust when I shut down and no pressure on the fuel rail when power is shut off. (Normal pressure when ignition switch is turned on-35psi), Gas also leaks out from the intake when the engine is tilted full up. Bad injector/s or leaking diaphram in low pressure pumps or both or leaking or fuel pressure regulator in/on VST? Recommendations??
Thank you for any assistance.
Unhappy Yamaha Boater
free access?
