billynjuls
Thread starter- Joined
- Jun 21, 2005
- 35
I hope someone can help. I have a 1992 Evinrude 150 Intruder. This morning as soon as I started up my motor a warning beep came on. At first it was a beep and a pause, beep and a pause. The tell tale has water coming out. I mix my gas and oil. After a while the beep stayed on constantly. Sometimes at idle it wouldn't beep, but as soon as I gave it a little throttle it would beep constantly and die. Every time I would go WOT it would stay on constantly before it would bog down and die again. There was quite a bit of white smoke coming out and the engine was shuttering at times. Every once in a while it would take off great for a while and then bog down like it wasn't getting fuel. I would turn off the ignition and turn it back on and the beep would go away for a minute. When I got back to the ramp I took off the cover on the side of the engine and where the anti-syphon valve is, the previous owner had cut off the end and hooked it up directly to the engine. The top connector had nothing hooked up to it. What's weird is this is the first time it has done this. It has been running great before. The engine isn't hot either. Would the way the gas line is hooked up to the engine without an anti-syphon valve cause this? Any other ideas. Sorry it's so long. Thanks.
Billy
Billy
