swimmin' for shore
Thread starter- Joined
- Oct 25, 2004
- 490
Fortunately for me, I was around for the "ping pong balls can float a boat" discussion, so this cannot ever be proven as the worst idea in boating history....not to mention the guy who wanted to put a 150 hp motor on a 14' boat last week....at any rate, I was building a cooler out of 8 lb. urethane foam last week, and I gave some of the overspill a beating with a hammer. The stuff was strong as could be, and hard also. I had just finished a new transom for my 78 Sea Nymph, and got to wondering if you could use the 16 lb. version of urethane foam to cast and build a transom. I looked it up on uscomposites.com and discovered the strength properties of it, and it's incredibly strong. I tried to look up the properties of plywood, as well, but have had no luck. I wanted to bring it up here, as so many of you have so many fantastic ideas. Would a transom, cast from urethane pour foam and then glassed over, be strong enough to support a motor under throttle?
